- Aug 10, 2019
- 2,556
- 5
- 0
Hello All,
I have a problem that has me completely stumped but im sure its quite obvious and that ive just missed it.
I have the 46HX703 linked with Sony ES3500 Amp and everything is working perfectly- TV is superb, picture is amazing and the sound through the Sony AMP is very clear. I have all the Sony Equipment linked on the Bravia Link and it works well- one button play etc.
The problem comes when trying to output sound back from the TV- I use the amp HDMI out to switch between sources- Sky HD, PS3 etc into a HDMI on the tv which is fine but I have also connected an Optical cable from TV to the TV input on the AMP but i get the error message
"Not avaialble when Control for HDMI is on"
- It almost seems the optical out will not work when using Bravia HDMI link which I find very strange. I have tried many different configuarations trying to use the ARC HDMI input to get sound to come back through but it just will not work- so far the only solution I have found is to switch to TV speakers to hear the sound for all Bravia Internet content which defeats the object of the surround amp.
I have not tried Phono cables output yet as I spent good money on a high quality optical lead and hope to put it to use.
I have searched all forums for a solution but no luck so if anybody has any ideas or found a way to use optical output from TV as well as Bravia Link then it would be much appreciated.
Many Thanks
MattDon
Many Thanks
MattDon
