I am going to purchase a Samsung LE40B650 Full HD LCD Television. I have heard the sound isnt very good so I am going to invest in a surround sound system. I do nohave the budget to buy seperates so I have been researching 'all in one' systems.
I will be using SkyHD mainly for sports (although they do not broadcast in DTS-HD, DolbyHD) I would like to get good sound out of the system, but also for the use with XBOX 360, PS3 & main stream Blu Ray.
I have been advised with either the Sony DBV-E300 & the Panasonic SC-BT205EB9K systems.
All I need to know is 1. which system would you recommend, which produces the best HD clear sound, 2. which system overall performs in SkyHD, Gaming & Blu Ray Cinema, and finally will they both work well with my TV
Thank you
Thank you
