I have just purchased this player and aside from a few issues with occasional juddery motion handling on horizontal camera panning shots with blu ray ( not present with dvd) I am v pleased with the picture.
One thing is v annoying though. If you press stop when watching a blu ray and then press play again to resume watching, the machine does not remember where you stopped the blu ray disc at. It does remember when watching a dvd so this issue is only with blu ray discs. Not only that but it goes through the motions as if you have just loaded a disc for the first time and takes ages before it takes you to the main menu which is a pain in the neck.
Anyone else experiencing this and is there a firm ware update to fix it? Anyone know if the 470 has the same problem? I might take mine back to Richers and change it if the 470 does not do the same thing
