Sony 32D3000 - Auto Aspect Format
Hi all,
I'm in the process of setting up and fiddling with my new system, and just have one little hitch to cure with the TV - The "Auto aspect formatting"
I have a Sony 32D3000 connected to a Dav-Is10 by HDMI and a Sky+ box with a 21pin scart lead. (there is also an old VHS recorder also by scart, but I'm not expecting too much from this connection)
I have been into the menu and made sure that the aspect ratio is set to "auto" but still the TV will not pick up the change in aspect ratio or for that matter automaticaly switch to the Sky input when the box is switched on (it's only just occured to me that the two may be linked somehow) The scart is fully wired (or at least it performed the above functions perfectly with my old Phillips TV)
Any pointers would be much appreciated, (you don't realise how much 4:3 content is still broadcast untill you have to use two remotes just to change the station.)
Many thanks,
David.
Does any one else have one of these sets?
How does yours work?
Thanks,
David.
