I'm looking to change my system in the near future.
As a starter I'd like to know if I can or if you can buy a splitter for the coax output on the Sonos.
Basically I'd like to keep the coax cable I have running to the AV amp in the basement and add a 2nd which would run into a DAC and then possibly into actives on the main floor.
The two systems would run simultaneously so I'd be interested to know if it could be done or whether I have to totally rethink this... The optical out is feeding a pair of Mackie actives in the garage.
Thanks upfront.
Thanks upfront.
