Sonos bridge with Airport Extreme
dryan
18
Does anyone know if the Sonos Bridge works with the Mk1 Apple Airport Extreme as I'm thinking about purchasing the sonos play 3 but don't want to spend hours configuring it to work with the extreme
The_Lhc
1,176
The AE's basically a router isn't it? Should be fine, as long as the AE is handing out IP addresses I don't see there being a problem.
dryan
18
Thanks for the reply, Exactly what i was thinking it has a WAN and LAN ports so should be ok - just wanted to know if anyone had a torrid time with this.
