- Aug 10, 2019
- 2,556
- 5
- 0
Hello all,
Have just bought a Panny 42"PZ85 and a Sony PS3. At
the moment I'm just watching Freeview with a Sagem Hard Drive box. When
I try to connect my PS3 the Freeview channels experience interference
on the box and the TV Freeview, lots of blocky pictures, and then when
I rescan for the channels lots are missing.
So removed the PS3
and its pretty much back to normal after re-scanning for channels a
number of times. So I tried even just connecting the HDMI cable
(Monster M1000) just to the back of the TV and got interference from
that too (without the PS3 connected).
So I know its probably just
down to a poor reception, so can anyone recommend a solution?
Unfortunately theres no way I can get up to the aerial, but as I say
reception is good otherwise.
Do I need a booster box (which I don't know much about) or is it something to do with 'dirty power'? (just using a cheap multi connector)
Any help appreciated, thanks
So removed the PS3
