Solid Tech Hybrid rack
iceman16
280
164
19,070
Im looking forward to get this soon. What's your thought?
Native_bon said:
Sounds bright to me... or looks bright...*biggrin*
The shelves are black with silver legs. Can add more shelves in future when required and save buying the extra legs. There are diff. colour variations like black-black or white-silver.
I just ordered this without the top left shelf. My amp and cdp wont fit in a normal size rack due to their wider size unless its custom made. The black-silver finish will also match the Kef Ref 3’s gloss black and silver front I think. And as a bonus my wife likes the look aswell.
What I look for in a good rack, is good shelf isolation, vibration control and the shelves themselves made from something that helps the sound, such as wood....ie. avoid Glass.
Are you getting the isolation feet?
Nope. I'll experiment first with my existing isolation feet(soundeck/vibrapods/valhalla pads etc.) to each component feet. Some are just gathering dust in the cupboard. There are two diff. types of shelf to choose from(wood/concrete) and I've chosen the wood with built in bubble level.
