T
the record spot
Sansui AU-717 amplifier Mission 752 floorstander Marantz SA7001-KI CD player Of those three, which one would you look to upgrade next? My current set-up gives me a good big soundstage and, I feel, a very impressive sound. There's no harshness, the detail is all there, but not at the expense of the overall music so it's not too forensic when playing discs. The phono stage is excellent IMO and on the few occasions I've had the turntable out, I've no complaints. It has two phono inputs, so I could add a second record deck if I wwanted to (although, as the first one's on top of the wardrobe until the children are bigger, that's not happening!). This isn't a case of being unhappy with the sound or the kit, but I'm at a loss to work out what I would change next. Cables, mains block and other fripperies are out of the question in terms of "improvements" over and above what I have just now - hence, not required. Standalone DACs are out as I need SACD functionality (none offer that). Budget would be say, £1000-£1500 level components each. Only one thing gets changed though, so what one would you upgrade and why? Reason for asking is I'm having a hard time working out which one would be next - as there will be a next - and I should add, although I often advocate active speakers, they're out just now, or at least until we move into a place of our own (wall mounting isn't an option in our current rented place).
