Smoothest sounding speaker upto £1000?
I am stretching my budget to a grand and want something smooth without brightness.
I rang audioaffair to enquire and Richard there went through some speakers with me and mentioned proac might be the best at that price range. i was initially interested in the Kf LS50 but he said they are still a bit bright as are the R100.
I am thinking of Dynudio but found the DM2/7 a bit bland for the money.
what would you guys demo or recommend to g with Marantz SR7005?
room modest 9ft ceiling; 9ft wide, 14ft long.
I do want to add center at some point and use my BX1s as rears.
Dont the Spendors lack in bass? I like to listen in pure direct without a sub for the best stereo sound.
The bass will be lacking compared to the Monitor Audio RX1, right?
Yes, the bass on the SA-1s are lightweight. Think that PMC DB1is maybe more suited to your taste: Has a lively top-end (not bright) and has thunderous bass for cabinet size.
Frank Harvey
567
Spendor and KEF R series will be about as smooth as you'll get under £1,000.
The trouble with finding something as smooth as you can is that you're then in danger of them sounding dull.
Yes indeed. I found the QUAD12L classics extremely dull!
I am in Manchester and the hi fi stores here dont have any dynaudio, epos, spendors, pmc etc for me to try.
This is the problem with smooth equipment: As you said it can sound 'bland or dull', so you need a sparky top-end to bring it alive.
If you tell us what brands are available locally, then perhaps we can advise further.
BenLaw
475
7
18,895
keenly said:
want something smooth . . .
You want smooth, but don't want bland.... I think you're (at best) treading a fine line, and recommendations may be difficult as everyone will have different interpretations of those two words and where that line is.
Paired with the Marantz, I would second the suggestion of ATC SCM11. FWIW, which is probably not very much (see above).
CnoEvil
556
13
I would look to brands like Sonus Faber, Opera, Dynaudio, Spendor and Harbeth......and as has been suggested, the Kef R Series, which are smoother than previous generation Kefs.
In store locally;
Monitor audio which i do not like at all. I have had the BX1s BX2s and RX1s Thus far. GREAT bass on RX 1s but vocals spit at you.
B & w again bright.
Audio T have some Kef in stock but nothing to compare them to other than MA.
Cheaper Wharfedale Diamonds but not the Jade models.
Dali zensors.
The Manc shops have a very poor selection imo. The above is pretty much it! Audio T have lots on their site but not in store. The same with Superfi who have a suberb selection on their site but not in stock at store to listen to.
Never hear of half of them and nobody anywhere near me stocks them.
If i could home demo from online shops i would be fine.
CnoEvil
556
13
IMO. The Kef R series are the class act among that list, and manage to be smooth, yet lively and exciting at the same time....give them a listen and see if you agree.
stevebrock
183
How about giving Doug Brady hifi a call, they do actually care about what your looking for, they will let your demo speakers at home. I bought some Neat Motive 3, got them home and they didn't work in my room, rang up John and he genuinely wanted me to have speakers I was completely happy with.... They let me take home some Rega RS1 that's sounded better then the Neats in my room at home.
Spent hours talking to him, he is a genuine hifi enthusiast and not there to make a fast buck.
Imho the only way to demo speakers is at home......I had always written of the Rega RS1 but they a fantastic musical speaker that really work well with the Brio R amp.
Thanks yes i will but i also want to hear the ATCs especially now i have found they do a center to match!
Ideally i would listen to the R100, LS50s and the ATCS SIDE BY SIDE.
I am currently treating my room and i am waiting for some 3 inch rockwool slabs to arrive. I have just ordered a Merlin mains cable and have a Tacima mains conditioner. I thought it would be best to finish the room then listen to speakers(if i could home demo a pair).
I see they like Monitor Audio :grin:
There's only 6 brands of speakers at Doug Hi fi but they do have the epos which i wouldn't mind hearing. The thing is i want to add a center as some point.
That sort of service is what i am after!
BenLaw
475
7
18,895
Hifi stereo does ATC, give them a call. They're in Sale. ATC C1C or C3C would make an ideal match with some 11s and should pair nicely with the Marantz. You will get the best out of them with a treated room :)
Rick @ Musicraft in Derby could no doubt help you out with ATC as well if you have any difficulties with Hifi stereo.
cheers. I will ring them tomorrow.
