I've got an old Arcam Alpha system with a pair of Royd Topaz speakers. For many years it's been great, but sadly over the last year or two the foam has disintegrated in the speakers, so I now need to replace them (Royd don't exist any more so sadly I can't get the speakers repaired).
The problem I've got is that the speakers are small (only 19 cm deep), and they are wall mounted which means that they're only 10 cm off the wall. For various reasons including the fact that the room is small, and used by young children I need to find a replacement that can also be wall mounted, isn't going to protrude much more than these (i.e. ~30 cm), and is going to sound okay this close to the rear wall.
Does anyone have any recommendations? Price isn't a primary issue (within reason!).
One of the only speakers I can find that is small enough is the Neat Motive 3. Any one know whether this will tolerate the positioning? Or the Neat Petite SX (although I'd rather not spend quite that much)
Mat
Mat
