Small speakers, low-powered amp, big room
bluedroog
8
Sounds like a recipe for disaster to me. People often make the mistake that small speakers are suitable for low powered amps but often the reverse is the case and the small cabinets make them inefficient and hard to drive. Something like the small Q-Acoustics 2010s sound like a completely different beast depending on what they’re on the end of. Small speakers in a large room are a compromise as it is, add a puny amp and I think a re-think would be in order.
Crossie
58
A few more details may help. What size room and budget do you have? It may also help to specify what you mean by small speakers, perhaps give us an examp[le of the sort of thing you are looking for.
Hopefully someone will be able to point you in the right direction.
Cheers.
ASK THE COMMUNITY
