Small 3.5mm cable!
Hi, im looking for a 3.5mm - 3.5mm cable to connect my ipod to a Graham Slee Voyager headphone amp... the only ones I seem to be able to find are at least 1m long, obviously too long just to connect these together. Does anyone know where I can find a decent quality cable maybe about 6inchs long?
Thanks alot.
I'm sure one of the cable companies woud be able to make you up a custom one, but it probably wouldn't be much less expensive that a 1m version.
Hm yeh I was hoping that wouldn't be the case! Ill give hificables an email, see what price they'll do one for.. hopefully it'll be a bit less, I don't really want to spend £40 or so on 6 inches of cable!
Thanks for the reply.
Well I emailed hificables 2 days ago to see if they did custom lengths but unfortunately got no reply off them..
Can anyone recommend a decent site for cables? (preferably one that delivers quickly!!)
Thanks.
