Sky Wireless - Annoying Little Box!!!
Hi, I have sky broadband and recieved a wireless router with the subsciption. I however, wanted to carry on using my old wireless router that i had purchased previously. The problem being that no broadband was coming through! So i eventually attatched the sky router and lo and behold it worked!
Finally, I come to my problem when i try to use the wireless dongle i bought to use with my router it simply says acquiring ip address and eventually times out
Anyone with any suggestions it would be greatly appreciated
Yousef
Do you mean you daisy chained the two routers together using ethernet? This does not normally work at all.
Why can't you simply use the router that Sky gave you?
No I am using the sky router but it doesn't allow any non-sky products to connect. For example, the BT dongle won't work as it ust says "acquiring network address"
