- Aug 10, 2019
- 2,556
- 4
- 0
In hope that WHFS&V refreshes the parts that other forums cannot reach…
I have a regular Sky+ box (so not HD) and my problem is this:
I only ever get a signal on one of the two inputs.
Signal strength and quality are good but only show for the first input.
If I swap the cables over on the back of the box – there is no change, still only the first input shows with good quality and strength.
Leaving one cable disconnected – I still receive the same results with either cable, on either input – thus I conclude that the cables themselves check out OK.
Thinking it must be the box itself (Amstrad) I have tried a friend’s box of the same make/model (known to be working fine on his dish) and get exactly the same results.
Other forums have suggested that the symptoms I see are due to a failing disk – so I have replaced the HDD and still I see the same problem.
A visual inspection of the LNB and dish indicate no obvious problems.
Can anybody shed any light on why I can only receive one signal.
Lest anyone wonders why this is a problem/irritation – I cannot record one channel while watching another.
