sky hd upscaling
Hi, i am a virgin media customer but thinking about switching to sky, but have a couple of questions.
Does the sky hd box upscale sd content and does the hdmi carry the dolby signal or will a optical cable be needed?
daveh75
Sky+HD boxes can indeed upscale SD content, however you're better off letting an A/V amp (if you have one) or your TV do the upscaling as Sky+HD boxes upscalers are poor!!!
You need to use an optical/coaxial digital cable - Sky boxes can only output stereo over HDMI
The_Lhc
1,176
cowbat:
It can do but it's not very good at it.
Optical cable needed.
thanks, i have a onkyo 606, not sure if it can upscale from a hdmi signal or just analogue
cheers, thanks for help.
will have a try of each one to see what is best once its ordered
