Sighted listening - you know exactly what you are listening to as you can see it. You will evaluate sound quality based on all of your senses and can/will be influenced by cost, looks, image.
Blind listening - you do not know what you are listening to as you cannot see it. You are asked to listen for any differences and comment on them. You are evaluating the sound alone as other influences have been removed.
ABX - you as asked to listen to component A, then component B, you cannot see which one you are listening to and are you are then asked to listen to X, which is either A or B and you are asked to say if X is A or B.
I am all up for all three types of listening. However, many audiophiles flatly refuse to do ABX as such listening often challenges the results of sighted and blind listening. ABX listening finds that differences in sound cannot be identified anymore, or are very difficult to identify. That flies in the face of many a 'night and day', 'vast' or whatever improvement or difference in sound.
Indeed ABX tests have yet to find any audible difference in cables, where the cable works and lengths are not excessive (i.e in domestic applications). ABX has found that amps and CDPs difficult to tell apart. Amps have been shown to be identical if equalised. Speakers are the one hifi product where ABX has found readily identifiable differences.
I therefore think that ABX is the most important form of listening. Afterall, if we are going to make claims about sound quality, we should at least be able to differentiate between products by just listening to them.
