Should my Humax 9200T be doing this?
kitkat
162
Thanks to everyone who helped me with my software update question. Since the update my Humax sometimes turns its self on just for a few seconds before going back to standby also I have heard the fan on even though the unit is just on standby I have only found this since the update is this normal?
After the update my Humax indicated that it was going to standby but the hard drive was still running, I have turned off the auto update and the machine now appears to be going to true standby.
Also on another Humax forum it has been pointed out that. "The machine may turn on to update the EPG and check for schedule changes. This should take no more than 15 minutes so if it happens again the OP should check if it has turned off after that time".
Hope this may be of some help
