buzz_lightclick said:
Set to bitstream = AV receiver does the decoding.
Set to PCM = Blu Ray disc player does the decoding.
Will you hear a difference? Probably not!
It's not just about hearing a difference. You are most likely right that there is no difference.
One issue I had was when I watched Day Breakers and had my player decoding it there was an error with the playback.
When I got my current amp and still witht e same player but now set to bitstream that error went away and the film plays back correctly.
Granted with the Total Recall remake with the player set to bit stream I got half way through the film and the disc crashed. The only way to get through it was to set the player to do the decoding.
The issue though was not my player or my amp but an authoring issue with the disc. I know this because I worked for the company that did the disc at the time. Not when they authord it but when I watched it and found the error. It was the US that made the error.
Player docoding is mainly for people who don't have and AVR to cope with the audio codec on the disc but as I've said before. With DVD, if the player doesn't have a DTS decoder in it you can't listen to the DTS stream.
Of course we are on BD now and all the player should have the means to decode the audio codecs available for BD but when the PS3 was released and other players that came out the same time they didn't have the means to decode DTS HD-MA or Dolby TrueHD for the simple fact those codecs had not been released yet. Firmware upgrades had to be issued for them to be decoded internaly.
I personally think it's best for the AVR to do itss job and let the player just worry about video.
