Should a buy an external Dac for better sound?
Zax89swe
23
Now Im playing my music through a computer soundcard, I wonder if a Hrt music streamer II would lift my system or should I wait and buy the more expensive Arcam Irdac instead for a more noticeable improvement?
ISAC69
73
I am not familiar with the Hrt music streamer II and I don't know which computer soundcard you have ( the more adventage ones have an excellent internal dac), but matching a DAC will certainly improve the sound! try also Rega DAC , Musical Fidelity M1 and Audiolab M-DAC .
spoorarthur
Definitily buy yourself a DAC, but I would't spend to much on one. The HRT streamer will do fine, as long as you don't need other inputs. Dom make sure to use the right software - and plugin(s). Visit the site computeraudiophile.com for more info about software issues. Enjoy your upgrade!
stevebrock
183
In the context of your system ie your amp then I would think the HRT II would be perfectly adequate.
Yes a £500 DAC would be better, but personally would look at upgrading your amp to realise a more expensive DAC potential albeit the PM6004 is still a nice amp but you will be still stuck with the marantz sound.
Zax89swe
23
Or should I buy Rotel ra-12 instead :wall: some say at the forum that Marantz sound smoother but I find my system very bright already, had before Rega brio-r and it had same brightness level as the marantz but slightly more power, had also the Yamaha a-s500 and it was the most bright (not a good thing) and clinical.
BigH
115
7
18,595
If all those amps are bright then its probably either your speakers or your room or both. I would not get the Rotel if you want less brightness, I would demo some different speakers, try the KEF R100s.
