Short analogue interconnects
Juzzie Wuzzie
177
Can anyone recommend short (i.e. 30cm or less) analogue interconnects? Russ Andrews sells 10cm 'amp jumpers' but was wondering whether there are others?
idc
1,113
68
19,270
I would suggest the shortest Van Damme ICs off eBay. The reason for that is the cable is very flexible and will easily cope with tight bends.
http://www.ebay.co.uk/sch/?_nkw=van%20damme%20interconnect&_clu=2&_dmpt=UK_Computing_CablesConnectors_RL&_fcid=3&_localstpos=PA8%207HL&_sc=1&_sop=15&_stpos=PA8%207HL&gbr=1
I made my own with the Neutrik phono plugs and they sound just as good as any other IC I have tried.
idc
1,113
68
19,270
My present collection of ICs is SHB Synergy 2i (not recommended as they are far too stiff for short runs), home made Van Damme Neutrik Rean (perfect for the job) and identical sounding Q-Audio hand made cables (again perfect for the job in that they are very flexible, but they cost $300 or £189 which is too much).
ASK THE COMMUNITY
