- Aug 10, 2019
- 2,556
- 5
- 0
Hello all,
After months of anticipation I finally bought the squeezebox duet but I cannot set it up! I think it might be a problem with my wifi router but I am not sure. The first steps went ok: I could find the wifi network and the squeezebox receiver. Then problem is that the squeezebox cannot connect to the music source. I use the following set up:
- wifi router: D-link system DIR-301
- windows Vista
- Anti-virus: Avast
I have the same kind of issue when using winamp: I cannot access my music remotely.
Does somebody have a solution to this problem? Thanks a lot in advance!
- windows Vista
- Anti-virus: Avast
