Sennheiser HD 598 vs Sennheiser G4ME Zero
Darkr
Hey community,
Name's Darkr... And I need help with a choice. Which one should I get??? Here are some links=
http://en-ie.sennheiser.com/pc-gaming-headset-g4me-zero
vs
http://en-ie.sennheiser.com/high-end-headphones-audio-stereo-hifi-hd-598
Also, if you know any better beyerdynamic ones better than the above ones, please tell me too. My budget id about 150 - 250 euro, the hd 598 are on 200 euro because of a amazon discount. I will mainly use this for gaming, maybe sometimes music.
Darkr
Although I havent heard the HD598 I think that you may find them a bit bass light for gaming on (based on my experience with Sennheiser's other HD*** models).
If your computer has a bass boost function in its sound driver software they'll probably be fine for gaming with otherwise other headphones may be a better option. Closed back headphones usually have more bass but sacrifice the open and airy sound that open back headphones have.
Hope this helps. 🙂
