Sell active speakers or amp?
Aayash
Hi all
ive just inherited a naim audio nait 2 amp, and a pair of Behringer Truth B1030a monitors.
I'm reliably informed there is no way these will work together, but I want to make the right decision with regards to which of these I should keep. Should I look into getting a pre amp to go with the speakers and my turntable and CD player, or look to get passive speakers to replace the Behringers? Or is there any other alternative?
Any advice welcomed as I'm not very experienced in this, but I'm keen to get the best set up possible. Thanks!
Vladimir said:
davedotco said:
Vladimir said:
Sell the Behringers and buy Linn Kans. :bounce:
I thought you liked a bit of bass Vlad, am I mistaken....... :?
Choosing the Truth (pun intended) would make the audiophile Jesus baby cry.
Maybe his dad could knock up a subwoofer or two........ :?
We used to sell loads of Nait2/Kan systems. With an analogue front end of course, usually a 'you-know-what'. Very communicative but poorly balanced, not really hi-fi at all but, in the right room and with a good player, great fun.
Depends whether the Nait 2 has the preamp output: it was a factory fit option, and if it's there it'll be top left on the rear panel looking from the rear. If it is there, should be easy to buy a cable to link it to the active speakers.
If not, I'd go the passive speakers route.
Keep them both, you can never have too much hifi. The Behringer's wouldn't be great actives, so if one has to go, I'd get rid of them.
Sell Beringers and get a Sondek. On a more serious note, get Rega Kytes for peanuts if you spot a pair. Naim IBLs would be the perfect partner, but you'll also be fine with any pair of decent modern speakers.
gasolin said:
The behringer is nothing special, sell them and get something decent like boston a26,monitor bx2,Q acoustics 2010i/2020I,concept 20........
Tannoy DC4 over any of them if a small room and two feet spare from the wall to site them!
