- Aug 10, 2019
- 2,556
- 5
- 0
Hi guys okay it seems like I slightly understated the dimensions of my room.
The dimensions of my room are width 3.7m * 3m depth
I really like the BR2's and as far as bookshelves are concerned, they do have bass, but they don't enough bass, it's snappy and tight but bass weight they are definitely missing
I am not looking at the sub woofer route as I am definitely set on floorstanders
The other gripe is that they are not as open and airy as they might be in the mid range, I am comparing them to my former AE Evo which were excellent for vocal openness
My budget is 350.00 or less, the speakers will be situated 10 inches from the side walls and 12 inches from the back walls
I know I am not going to get the best of what floorstanders can offer with this budget in mind but I am just looking for a significant improvement on the BR2's.
Cheers guys
Cheers guys
