Question Screen recommendations?
MMohammed
Community Manager
Oct 28, 2019
35
14
545
Hey, folks!
So, I'm finally looking to add a second screen to my home office. Laptop stand or not, using my laptop alone for hours of work is taking its toll on my neck. So, I'm wondering if there are any recommendations for a good monitor I can use as a second screen. My work includes a ton of Drive Docs, spreadsheets, and the like. Don't need anything particularly fancy in terms of video quality.
Any suggestions would be very much appreciated!
Hello
I usually find that the Iiyama or Aoc range of monitors pretty good.
However if you are not really bothered with the picture quality, then really any monitor manufacturer will be okay, However I would suggest that you could concentrate on the build aspects of your purchase, such as adjustable tilt and height features, and also not forgetting the type of connection to your laptop.
Hope this helps.
