Saving space
I was wondering if there is a way and what equipment I would need in order to just have a television in the bedroom on its own, and for it to be able to receive signal from DVD and satellite hardware in the living room.
Please can you advise what I need for this and if I get a good reception. Just trying to avoid having a DVD player in the bedroom as well and just have a wall mounted TV and also I don't have to worry m,uch about cabling.
Thank you
Used to have something similar but it was ropey to say the least. Currently use the second output (antenna) on the Sky box and a signal distributor in the loft to send Sky all over the house (have to watch the same channel as the living room). There's a little device that you can plug into the aerial "circuit" at the TV end, that allows you to use a Sky remote to control the Sky box as if it is in the same room.
I do have a DVD player in the bedroom as well.
