- Aug 10, 2019
- 2,556
- 2
- 0
Dear readers,
** I originally posted the following in the Home Cinema forum, but was advised by the good professorhat that it might be better to post the question in this category instead, even though it might technically be in violation of house rules #10. Hopefully Andy E or other moderators are forgiving...the posting in Home Cinema can be deleted. **
"I searched through forum topics and a globally
used search engine for the answer to the following question, but have
been unable to find a good answer. Perhaps you can help. Please
forgive me if I am not posting in the appropriate category.
I'm
a very pleased owner of a 9th generation Pioneer PDP-LX5090 HDTV that
works just wonderfully in combination with a Panasonic DMP-BD35
Blu-Ray player. I also have a satellite dish that has 2 LNB (one for
Hotbird, the other for Astra). I also own a nice but not so recent
digital satellite receiver (EchoStar DSB-880 2ci) without HD capability
that I used with my previous non-HD CRT television." I should note that I have not subscribed to any of the providers mentioned (Sky, Freesat, Virgin, etc.). I simply receive the satellite signal and using the EchoStar watch free-to-air or use my CA slot with a card, but as I said it doesn't have HD capability.
"Is it
possible to connect the coaxial cable directly from the dish to the ANT
input terminal on the Pioneer TV and receive the signal (either free to
air or scrambled via the Pioneer's CA module/smart card slot) and use
the TV's DTV capabilities to search for (and display) the programs?
I'm also wondering if I will get both audio and video and HD
programming with this setup, or if I will get absolutely nothing
? I
confess that I would experiment doing this myself, and answering my own
question, but I fear to damage the rather expensive Pioneer." If anyone has the theoretical technical knowledge regarding the Pioneer capabilities and satellite signal technology, then perhaps they can answer without testing it..or at least be able to tell me if I can test it without damaging the Pioneer.
Regards and thanks,
Johnny_C
I'm
"Is it
Regards and thanks,
Johnny_C
