satellite adjustment needed - advice?
eggontoast
451
9
18,895
If you have a subscription with SKY call them, you should be able to get it done for free. You will have to either move the dish to get a clear line of sight or chop the tree down though. If you are feeling adventurous just purchase a signal strength meter off eBay and move the dish yourself, it's a simple thing to do I put my one up OK.
Big Aura
509
8
18,895
yep, sky will generally do it for free if you're on contract. If not, a local fixer should able to re-site the dish for £60-100. If you're feeling handy - it's not that hard to do.
Plug your post code in here and then drag/drop the pointer to the exact place you're putting the dish. Zoom in and print it off. With the aid of that, a compass and a spirit level, it makes for a fun afternoon! (Make sure the dish is perfectly level). I bought a Sat Finder but found it a bit rubbish, it's better to have someone downstairs watching the screen with them shouting when you hit the sweet spot.
ASK THE COMMUNITY
