Sansui WLD201 LX Unit is not starting , blank screen, no response from unit
bigolli
Hello all,
my name is Oliver an i am from germany. I own some hifi and home cinema equipment from Marantz, Rega, NAD, JM LAB and a Sansui Network Player.
I just received this network player a few days ago from audioaffairs.
Installation was easy, working fine with my synology 214play but only for a few days.
Today when i want to start the player again, i noticed that the the screen stays blank and the player did not
started.
Power is oK, remote control is working, i disconnected the player from the power line and connected it again.
Nothing is working and screen stays blank, looks like it is not going into the start up modus anymore,similar to a microsoft computer.
Any idea? Can anyone help me?
Problem, you cannot buy this product in my country (germany) and in case no one knows a solution for this problem, i have to send the unit back to the uk.
Appreciate your help 🙂
thanks
kind regards
oliver
Try emailing these people:http://www.mitchellandjohnson.com/contact-us/4580897435
They are the company who make this product and may be able to help you.
Regards
Shaun
Hello Shaun,
thanks for your help. Whats happen with their Sansui project?
As i haven`t heard anything the last days i contactedt henley/sansui distributor, the technical dept.
After investigating that told me, my player is "dead" i should send it back to may dealer as there is nothing they
can tell that i can do at home to start it again.
So the player is now back on its way to the the uk.
Hope i get a more reliable soon as i was satisfied for the short moment when it was working.
Regards
Oliver
