- Aug 1, 2019
- 4,505
- 67
- 0
Samsung’s top 2020 TV is the most compelling 8K model we’ve seen, so is now the time to jump in and invest in an 8K set?
Samsung QE75Q950TS : Read more
On the other hand, wait until there is enough content to make an 8K TV worth buying. They will likely be cheaper then. Why pay the early adopter premium, when there is barely any 8K content to watch?But if you have the budget and an appetite for a degree of future-proofing, the Q950TS is the best case yet for taking the plunge.
^^Oled fanboy^^Don’t buy this television, the screen quality is very poor, it suffers from dirty screen effects and vignetting. For the cost it is just not worth it, I sent mine straight back, I could see the screen issues as soon as I turned it on !!!!.
I have gone OLED, a much better technology, Samsung need to get their act together, customes should not have to play the screen lottery.
Not at all but I have had both and the Samsung suffers poor screen uniformity I’m sorry to say and OLED appears to be much better in this respect.^^Oled fanboy^^
I agree 100% with this. I purchased the Q900TS and was incredibly disappointed with the image quality. As a smart TV features wise it is second to none, but all in my household agreed how much Bette OLED looked even though it is 1/4 of the pixels.Don’t buy this television, the screen quality is very poor, it suffers from dirty screen effects and vignetting. For the cost it is just not worth it, I sent mine straight back, I could see the screen issues as soon as I turned it on !!!!.
What was the OLED set you decided upon in the end?Do not buy this TV, I bought it and had to send it back for replacement due to motherboard issues, light bleeding from the edges and power management issues. Second TV they brought had similar issues with light leaking and power management. Specifically, the bezels are so incredibly thin that they seem to have struggled to keep everything tight. The bezels had random corners or edges where you could see the backlight of the TV bleed outside. Also, both units shut off on me and wouldn't turn on, had to exchange the cable. While these issues might be unique to me, the screen definitely has serious Dirty Screen Effect and unfortunately, it IS visible for regular viewing. For a TV at this price point it is unacceptable. I had to turn it back and change for an OLED. I was very sceptical of OLED due to burn in and brightness, but so far it is brilliant and I love Dolby Vision. If you want to stick with Samsung get the Q95T or wait for next year's QLED.
Many thanks for your reply! A few of more about the GX if you don’t mind::I got the LG GX. It is brilliant. Love the menu, picture quality, sound, you name it. I wish it was a little bit brighter (I think I read GX is less bright than CX) but it only detracts 10-15% of my experience for daytime viewing
Great thanks again. Will check out the LG soon!I got the 65 inches version and I mounted it on the wall. Build quality is great and sound quality also really good. Dialogue is clear, sound effects punchy I'm actually really impressed by the sound quality although I use an external 5.1. loudspeaker setup.
