- Aug 10, 2019
- 2,556
- 4
- 0
I was all set to get the samsung then this panasonic cropped up in my local av store. Im a complete home cinema novice and alot of the technical stuff just baffles me!
I really like the look of the q97 samsung but ive been told the panasonic is a better option as it will accept a 1080p signal and 24fps.
I have on order an onkyo tx-sr576 ( still not sure if ive made the right decision on av receiver) , Q acoustics 1010 package with an upgrade to 1030 floorstanders and a pioneer dv600av upscaling dvd player.
Now as far as i can work out the pioneer will upscale my dvd's to 1080p so does that mean the Panasonic will be the best option? I also plan on getting a blu-ray disc player later on in the year.
I understand it would probably be better to get a full hd set but funds wont allow that at the moment, and from what i could tell there wasnt a massive difference between a full hd set and an hd ready set being fed casino royale on blu ray anyhow. (is my vision really that bad?)
Just to throw something else into the mix! ive just seen a th-42px80 and was very impressed by the picture quality both in sd and hd formats, i really wanted a 50inch but if this set is a big step forward from the other two ive mentioned then i will happily plump for that.
I never thought deciding on a tv would be so difficult! its without doubt the most stressfull way to try and spend £1000.
many thanks stewart
many thanks stewart
