Samsung LE46M86BD v LE46F86BD
Can anyone tell me what the main differences are between these 2 models as both are 5 star rated in the magazine but there is a a £400-£500 price difference. Pixmania are doing a deal for the "M" model plus PS3 for approx £1,400 which is about what you can get the "F" model for. Is the "F" worth the increase?
The F86 has the following:
100hz (which isn't any good apparently, many switch it to low/off).
Higher contrast ratio, if that makes any difference in real life.
Justscan on component if you want it.
Has a USB port for playing MP3/JPG from a USB stick (wow!) and I guess the USB can be used for firmware updates too, but I know for a fact that the latest available firmware requires an engineer visit because Samsung UK will not release it on USB like they have in Australia
I have ordered the F86 though, it's meant to be better, but only you can decide if its worth the extra.
