Samsung LE46M86BD or LE46M87BD
cball313
16
Hi All,
I am looking at getting a new TV and am looking at the Samsung LE46M86BD following some good reviews. Can anyone tell me the difference between this and the LE46M87BD? all I can find is the LE46M86BD seems to be discontinued.
Does antone have this model or recommend a better one?
Samsungs got a new LE46F86 range at round about £1500 this gets better reviews mostly due to slightly better blacks than the M range. I`m personally getting one from Robert Whyte as they do a free 5 year guarantee with it for £1499. Put a search out and see what you think. Here is a link that might help with a test review.
http://www.hdtvtest.co.uk/Samsung-LE40F86BD/
The m86 and m87 are one and the same I believe - depends on whether or not you buy them from the dixons group
The f86 is superior
I have the M87.
When i was deciding between the 2 the only thing i found was that the M87 runs at 100hz which i couldnt find that speck on the M86 unless i missed it?
hi
i have just bought the 40" version.
i wonder if any one can help me, as i cannot get the picture in picture to work.
also i am at a loss to get the correct or best settings for the picture.
Hope this helps Maxy, 86 and 87 are the same specs so...
http://www.hdtvtest.co.uk/news/2007/04/22/samsung-le40m86bd-settings/
