- Aug 10, 2019
- 2,556
- 4
- 0
Misses says one day two at a push.the record spot said:What's the battery life like chaps? Can you get into a second day even with "real world" use? I don't mean hammering web, tets and calls, but regular stuff - I'm a heavy web user at times, with the odd text and my Nokia E52 lasts well into two days.
The only other phones I'd consider just now are the Motorola Atrix and Smasungs Galaxy S2 which has a beefier battery (1650maH I think). Thoughts on the Ace are welcome though!
the record spot said:OK, thanks chaps - that's that one chalked off the shortlist then...!
the record spot said:Ah, au contraire mon ami, Three are absolutely fine. Been with them for three years now and never had a problem. My sim-only deal is about the best you'll find out there - £8 a month and I get unlimited data (and that's not fair use either), 2000 minutes, 10,000 3-to-3 minutes and 5,000 texts. No issues. And I see the rest are starting to catch up. I hear Three were poor to start off with, but they're absolutely flying now. No way I'd change from this deal or the company.
