- Aug 10, 2019
- 2,556
- 4
- 0
Hi all, I know this has been discussed at length, but I'd appreciate your thoughts on suitable interconnects for my particular Cyrus and MA system.
Current system is: CD8X -> Pre VS2 -> 2 x 8 Power's running in mono, bi-wired to MA RX6's. Speaker cables: Cyrus bi-wires same as the DNM design stuff and interconnects are Chord Cobra 3's. I also use a Sonos ZP90 to pull through music from Spotify / music server and an upgraded Rega Planar 3. I plan to upgrade the CDP to an 8SE later this year, shortly followed by the Pre which will go to a Pre XPd so that I have a decent DAC for the Sonos and other digital sources. I will also get a PSXR or two once I have sorted the hifi rack to accommodate it / them. Oh, I have also upgraded the power leads and have power conditioning.
The reason for wanting the change is that we have recently moved home and having been quite constrained on listening to music in our previous place - it was a converted Edwardian flat - I am now able to listen to my system the way it was designed to be. As such, I've found the current configuration to be a bit restrained; there's nothing wrong with it, but I think I can exploit what I've currently got somewhat more. I'd like the system to have an increased sound stage, retain the current spot-on timing and generally increase the overall musicality, without things becoming too bright as I know the Cyrus / MA combination can be.
The reason I'm only looking at the interconnects for now is that the speaker cables are run under the floor (I'll never understand the missus's dislike to cables) so they can't be changed and I've not had the MA's for long, so I can't justify replacing these just yet. I'd also like to stick with the electronics I've got for now, as the upgrades mentioned above will come once funds have built up again. Being impatient and loving to tweak, I'd like to do some fettling now.
So, my current thoughts are; Chord - Chorus 2, Missing Link - Alaqeia with Eichmann bullets or Van den Hul - The First / Second. Budget wise, I'm thinking circa £200 per pair. I've recently borrowed some Rega - Couple interconnects, which are fine, but I don't feel they add anything to the system, which I suppose is what they are designed to do. I'll obviously try to audition the cabes first, but I'd appreciate your thoughts.
The room the system's in fairly large with carpeted floors, rugs and two large sofas so we're not short on damping. Many thanks for now.
