Running in brand new Subwoofer
JohnHolmes
31
Hi fellas
Do I need to run in a brand new sub before running antimode 8033 to eq it? Or can I just run antimode 8033 straight away?
Do Subs need running in?
I dont know what antimode is, but my RSW12 took a good solid two weeks of running in, as it sound terrible, lack of power ect..
Now after a month,..... WOW
After owning 3 different subs I noticed a clear improvment with running in, it was like night and day
JohnHolmes:
Hi fellas
I would agree with Canada , the Sub needs to be run in
The woofer is stiff when new and will loosen up with use , the electronics will also "burn in "
Antimode is so simple to use it would be no hardship to run it with the New sub ,and again after run in.
Canada if you don't know what antimode is I respectably suggest you do some research , you might just find its your next upgrade/purchase
You can run your 8033 straight away, but once the sub has run in - I'd recommend giving a sub a good 50-100 hours - run it again, as it's characteristics tend to change quite a lot, as Canada has found out.
lesmor:Canada if you don't know what antimode is I respectably suggest you do some research
That could have been worded better! Sounds like something I might say...
For what it's worth Canada, I've never heard antimode whatever it was, so you're not alone...
the_lhc:
You can't help yourself from trying to give English and grammer lessons can you, pehaps you should consider if you are on the right forum
If you are serious about getting the best from a Sub /system then some research on "Antimode" would perhaps be of benifit
lesmor:the_lhc:
You cant help yourself from trying give English and crammer lessons can you,
On this occasion that wasn't what I was doing, I was simply suggesting your response sounded unnecessarily aggressive and dismissive of Canada's reply and could have been worded in a less hostile fashion, as I didn't think it was your intention to come across like that.
On the other hand however...
the_lhc:
Have a look here.
the_lhc:lesmor:the_lhc:
lesmor:Canada if you don't know what anti mode is I respectably suggest you do some research
For what it's worth Canada, I've never heard anti mode whatever it was, so you're not alone...
I certainly hope Canada nor anyone else was not offended as no aggression was intended, I did say respectably
To clarify ,as Canada has in recent times bought ,sold ,and upgraded his Sub and like most here his Home cinema is his Hobby, doing some research into anti mode might well squeeze more performance from his system although he might feel that the cost is not justified, or indeed he might now be happy with his system as is.
I did not want to detract from the original post by starting a discussion on anti-mode or room modes ,most posters here probably do not want or need to understand room acoustics
lesmor:JohnHolmes:
Hi fellas
Dont get me started, just sold a 2 month old R370HD to buy this RSW12.. lol, No offence taken,
