Running cables in trunking.
I'm in the process of redecorating and moving things about and I
want to run all my cables along the skirting in plastic trunking. The
cables will be HDMI, Optical, analogue interconnects, tv aerial lead
and speaker cables. Are all of these ok to be run together in the
trunking or should some of them be kept away from each other? There
won't be any power cables running along the skirting.
I would say (someone is bound to say otherwise) that as long as you use good quality well shielded cable and dont run the power with them you will be fine
I concur
Thanks all. I thought I would be ok but thought I'd just check.
When I first read the title of this thread I thought it was about running in cable trunking (no doubt somebody somewhere reckons that would make a difference!
