C cheyworth Well-known member Jul 13, 2008 145 2 18,595 Visit site Apr 26, 2009 #1 After a full side of an LP when lifting it off the cork mat comes with it due to static what can I do? Chris
chebby Well-known member Jun 2, 2008 1,253 26 19,220 Visit site Apr 26, 2009 #2 Get anti-static sleeves and an anti-static carbon fibre brush or some double sided sticky tape.
A Anonymous Guest Apr 26, 2009 #3 chebby:some double sided sticky tape. wont that make it even harder to remove the record from the mat?
John Duncan Well-known member Jan 8, 2008 2,033 27 19,720 Visit site Apr 26, 2009 #4 fast eddie:chebby:some double sided sticky tape. wont that make it even harder to remove the record from the mat? A ha. A ha ha ha h......ahem. Does the felt one behave the same way? Nagaoka inner sleeves help a lot though, as cheb says.
A Anonymous Guest Apr 26, 2009 #5 the felt mat did on my debut III. sorry i couldn't resits the tape comment.
chebby Well-known member Jun 2, 2008 1,253 26 19,220 Visit site Apr 26, 2009 #6 I had problems with the 'skimpy' felt mat you get with the Rega P2. (Not so much with sticking to the record but 'crumpling'.) I bought loads of anti-stat sleeves anyway and the blue Rega turntable mat (same grade as the P3-24 mat) which is thicker and heavier and...err, bluer ..... http://www.rega.co.uk/html/TT%20mats.htm
John Duncan Well-known member Jan 8, 2008 2,033 27 19,720 Visit site Apr 27, 2009 #7 I'm so having one of those blue ones...
A Anonymous Guest Apr 27, 2009 #8 They should really post a proper picture, the little paint generated circles don't make me want one at all. Surely they are not that bright?
John Duncan Well-known member Jan 8, 2008 2,033 27 19,720 Visit site Apr 27, 2009 #9 Judging by their plinths, I wouldn't bet on it:
chebby Well-known member Jun 2, 2008 1,253 26 19,220 Visit site Apr 27, 2009 #10 Oh they do better than that now.... And yes, they are bright! (My mate has the yellow mat and it is 'highlighter pen' yellow. Love it.
A Anonymous Guest Apr 27, 2009 #11 I'll stick with the black standard mat i think, as my P3 will be the high gloss black. Although a Blue mat would go nicely with the led's on the moon kit. Hmmmmm
John Duncan Well-known member Jan 8, 2008 2,033 27 19,720 Visit site Apr 27, 2009 #12 And the blue LEDs on my phono stage hmmmmmmmmmmm
A Anonymous Guest Apr 27, 2009 #13 thats the real reason i went for an all moon set up. it looks lovely. and blue is so much better than green or red.
nads Well-known member Nov 29, 2007 995 323 19,270 Visit site Apr 27, 2009 #14 Yep a Full Moon is better than a Half Moon.
T the record spot Guest Apr 27, 2009 #15 This just in from the book of impractical suggestions (hi-fi supplement) - nail it in. OK, a bit excessive, but worth a try surely?!?
G gbhsi1 New member Mar 5, 2008 237 0 0 Visit site Apr 27, 2009 #16 ermmm...is that pink I see on a turntable??? shocking! literally
