- Aug 10, 2019
- 2,556
- 4
- 0
Hope someone can help, I am thinking of adding the rotel RSP1570 surround processor / amp to my system (see below), this would be done over a period of time so I would start with the amp to my front two speaker using the pre out on my vsx- ax5i then at a later date change the rest of the amps and then the processor. so I am trying to find ideas of which amp would sound good with my MA RS8 speakers?. Ideally I would like to change the processor first and then use my pioneer just as a amp, with the rotel. However I do believe that this will not work ( would you be able to connect the rotel into the multi channel inputs on the av receiver to by pass the av processor)
