- Aug 10, 2019
- 2,556
- 3
- 0
I have to following:
Rotel RA820BX4 Amp
Rotel RCD865 CD
Rega Planar 3 with RB300 arm and Linn K5 cartridge
Kef Coda 8's on Target stands
Cable Talk - Talk Talk speaker cable, and QED interconnects.
The Rotel Amp switches are getting a bit flakey and I often lose one channel, wiggling the switch fixes it for a while. Should I get it repaired or retire it ? What would I need to spend to get equivalent quality ? The whole system seems to be getting a bit loose, particularly the bass, although the turntable is better and output from VBox also sounds fine.
I know the CD and Amp have a reputation for softness but it does seem worse of late.
(I'm sure you learned advisors will remember the RA820BX4 is much better than the RA820)
Rotel RA820BX4 Amp
Rotel RCD865 CD
