rooms influence to bass performance
ntune
22
How much can bad speaker positioning affect to bass performance? I bought pair of cerwin-vega 12" speakers, and they are lacking bass, until I give it +6 boost, and even then they sound poor. It lacks the punch, that you feel in your chest and rumble in your gut. They sounds just like basic multimedia speakers. I have double checked everything (polarity, settings, sufficient RMS). May the bad room shape eliminate all the power of the bass this bad? Should I try the outdoor?
Frank Harvey
567
What size is your room?
Which amplifier are you driving them with? And what is the impedance and sensitivity of your speakers? CW's are usually high sensitivity, so unless your amp isn't up to the job, there shouldn't be too much of a problem.
And yes, the room can have a huge effect on the bass performance of any speaker, particularly ported ones.
bluedroog
8
chebby
1,253
26
19,220
Are you both having this problem?
ntune
22
4.8 x 3.5m, sloped ceiling on both sides, speakers in the corner just under the slope.
SPL: 90.8 dB (@ 8 ohms @ 1 meter full). Im driving them with the t.amp E400. the t.amp E-400 stereo amplifier - output power: 2x 190W @ 4 ohms, 2x 120W @ 8 ohms thomann (@1kHz, THD<=0,1%), 20Hz-20kHz frequency response, >120 damping factor, XLR, balanced jack and RCA inputs, Speakon & Binding Post outputs. Protection: DC, short circuit, temperature & limiter. Power supply: 230V~50Hz. Dimensions: 482 x 317 x 88mm (19" rack/2U). Weight: 8.3 kgthe t.amp E-400 stereo amplifier - output power: 2x 190W @ 4 ohms, 2x 120W @ 8 ohms thomann (@1kHz, THD<=0,1%), 20Hz-20kHz frequency response, >120 damping factor, XLR, balanced jack and RCA inputs, Speakon & Binding Post outputs. Protection: DC, short circuit, temperature & limiter. Power supply: 230V~50Hz. Dimensions: 482 x 317 x 88mm (19" rack/2U). Weight: 8.3 kg
chebby
1,253
26
19,220
Just to illustrate ntunes setup...
http://i54.tinypic.com/2jaan28.jpg (for bigger view)
cheeseboy
245
Lee H said:
cheeseboy said:
could be wrong but that looks more like a set up for very large room, used in a very small room. Super overkill! With all that wood as well, the sounds will bounce around like a powerball....
You're not wrong, but this one is a troll.
Exhibit A...
http://www.whathifi.com/forum/hi-fi/room-acoustics-0?page=2
ahh fair enough, thanks for letting me know. That picture kind of reminded me of the start of back to the future :)
