[quote user="drummerman"]
You've spent a considerable amount on your components so I could understand if you're a little bit hesitant to change any one of them. The most likely case is that your current system just shows up bad recordings, unfortunately a bi-product of high resolution playback. You will get used to it and my bet would be if you now go back to your previous primares you'd miss the extra rythm and attack, some of which especially if its leading edge transients which include many treble happy instruments can come over as brightness. Meanwhile, have you tried more obvious things such as loosing your line conditioner and using the power cords supplied with your equipment? Sometimes aftermarket improvements/solutions dont help.
[/quote]
I certainly agree with you that my Primare setup is more forgiving on poor recording but not for Naim. My initial setup for Naim was using stock power cord and without any line conditioner. But after doing some homework i started DIY couple of power cord with pretty good result. By adding line conditioner it bring the set to another level, the floor noise is lower on top of that music seems have better depth and definition. Beside the Naim gear seems to be rather sensitive on power cord too.
