Roksan puzzle.?
alchemist 1
111
26
18,620
I have a roksan tabriz arm that has been fully serviced and all new bearings fitted and is as good as new.
My dilemma is do i find a suitable turntable for my tabriz or go for a rega rp3 or 6 with their new rb303 tonearm included.?
Personally I'd stick with Roksan turntable as the Tabriz will be sure to suit them, an arm like that deserves the best.
I have seen a Roksan Radius (without arm) going on Ebay at the moment.
Should be an ideal pairing.
You do not mention a budget though.
Alears said:
Personally I'd stick with Roksan turntable as the Tabriz will be sure to suit them, an arm like that deserves the best. I have seen a Roksan Radius (without arm) going on Ebay at the moment. Should be an ideal pairing. You do not mention a budget though.
I had that particular radius model before , so an alternative t/t is required. Budget £600-£1000 inc cartridge. 🙂
Alears said:
In that case flog the Tabriz and go for a second hand Michell Gyrodek, or indeed the new Rega Planar 6.
And if you do sell the Tabriz let me know, please.
As a Radius owner myself can I ask what it is that you find unsatisfying about the deck? I'm always half-contemplating selling mine and trying something else. Not because I dislike it but I know there are better players out there.
Exactly the same reason as you charlie, also felt like a change.
Will keep you in mind when i've decided which path to take. 🙂
Thanks, sorry if I was slightly presumptuous.
