Roksan Kandy K2
smbmetal
117
26
18,620
Hello all,
Current system - Rotel RC-03 Pre Amp & RB-03 Power Amp. (B&W 602 S3 Speakers, Arcam CD92T)
I'm thinking about asking Santa for the Roksan Kandy K2 for Christmas. Does anyone have any thoughts of whether or not it would be a good upgrade to my Rotels? At this stage I have no interest in replacing my speakers or CD Player.
I listen to heavy rock/metal music if that helps.
Thanks!
plastic penguin
Not sure you'll get anymore detail than the Rotel pairing. Rotels, Arcam and B&W sounds like a cracking combo. If you're looking at weak links I would suggest the speakers are it. The 602s are wonderful speakers, for the money, but your Rotels will sound better with a more refined, expensive speaker. The likes of PMC DB1is are fantastic and should sound great for rock/pop with your amp and CDP.
smbmetal
117
26
18,620
Thanks for your thoughts.
Personally I thought that my rotel's were still at the 'budget' end and wouldn't be good enough for better speakers.
The only issue I have is that I have matching B&W's for my cinema setup (The 602s3 at the front, 600s3 at the back and lcr 60s3). Changing speakers could cause tonal issues? Guess I could always look at B&W CM5's?
plastic penguin
Yes, your pre/power amps were (are) the entry-level models. But having separate amps, generally speaking, will give you more flexibility. So I would guess your amps are roughly the quality of the aforementioned Roksan, and will benefit from better speakers.
Understand the speaker matching thing, so try and get a pair of CM5 or 685s on home dem and see how they stack up.
Personally speaking your combo would flourish with a £1,000 plus speaker. Perhaps something to bear in mind for future upgrades.
If you are determined to change amp then look at this http://www.ebay.co.uk/itm/Leema-Acoustics-Pulse-Integrated-Amplifier-Silver-Ex-Display-/170717260845?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item27bf8aac2d
I own the Leema and, I'm very biased
, it is the best integrated amp I've heard below the £2k mark. However, again, whether the speakers will do it justice is another question.
My core set-up: Leema Pulse; Arcam CD73T; MA RS6 speakers.
Hope that helps.
Looking at your current set-up the things I'd change, if you feel you have to, would be the amp to a Rotel RA1520 ( a much better, allround and more detailed amp with a solid soundstage and great, well timed bass) or possibly look at the NAD C356BEE integrated
The Rotels youve got are good but they can be bettered; more so with a more powerful amp with more low-end grunt and a better overall grip
Both the Rotel RA5120 and NAD are solid, gutsy amps and will drive the B&W's youve got very well indeed
However I do also feel that your CDP may be holding the system back a little as well; more so for your taste in music
The likes of a NAD C545BEE, Rega Apollo or even a 2nd hand Arcam DiVA CD192 CDP would be a definite improvement. These have all got a more faster paced and detailed soundstage un comparison to the Arcam CD92 IMO and will do well with the music you listen to
I always loved the 602 S3's; had them for years with varying Arcam, NAD and Musical Fidelity amps; I too listen to a fari bit of rock/metal (everything from SOAD to Disturbed to Metallica/Iron Maiden & so on) and the B&W's always sang their hearts out with this music
But they do require a solid amp behind them and personally I'd favour either the Rotel or NAD amps; even the likes of an Arcam Alpah 10 or Arcam FMJ A32 would be a solid improvement IMO
The Leema Pulse and Creek Evo II amps would be good as well but I dont feel they'd get the speakers to sing as well as the other amps I've mentioned
smbmetal
117
26
18,620
Thanks for all the replies so far.
Lots of great suggestions. Think I'll have a visit to my local shop, take my rotels and cd player and see.
Thanks!
Shanka
123
I looked/listened a lot to the Kandy last year and my initial suggestion would auditon that with a couple of other amps as suggested above and then get a home demo and see what you think.
I was looking to pair the Kandy initially with some B&W 603s3's and thought it was a good pairing, I was also considering the Naim 5i ( not good with B&W)and the Leema mentioned by pp, I would also consider the Rotel 1520 although I have not heard but works vey well with B&W by all accts.
I didn't go for the Kandy because I heard the Caspian but it ticked all the boxes, however if you can get a sale or return on the leema I would give it a go because it is a great amp, looks good and is good value at the price.
Best under £2000, not sure , see below..........................
Your ears will tell you what you like and there is a great choice at this price , any dealer in this climate should be able to let you have a demo one for a day at least.
Good luck, have fun
