roksan kandy amp k2 owners
rymidd
36
i have notice a hum buzzing sound from one channel, the other channel has it but you can hardy hear it in that one. is these normal, the noise is more than my old nad 326bee. also there a noticeable hum from the unit its self in standy by. you can only hear the noises when near to the unit
Hi Rymidd,
Well my Roksan K2 has the same hum at nil volume but it has no effect on performance. However I don't have a hum from the amp itself. Try the roksan website for more.....
I also have this humm, the right channel louder then the left, also when playing on low volume the left channel is louder. When playing on higher volume it's there but not as up-front.
The amp to has this little hummmm..
Just having it for a few day's this amp.
after looking at the replys i dont think i got a faulty one , this one has just replaced a fauty one which the speaker holes where to big so i did not even try that one.
i was comparing the noise with a nad 326bee which is quite as a mouse.
may be it a case of more power more noise
What do you mean with speaker holes are to big?
I've bananaplugs and they fit a bit to easy also.
Yup, I have that hum too, also in the right channel. Not enough to make me do anything about it though. Sounds like it's pretty standard.
No hums from mine.
The left speaker is noticeably louder than my right speaker though.
My Roksan gives a louder sound over the left one too, also the hum is more on the right side.
I'll be sending it to the dealer for repair.
