Hi all you fellow Mac users that might be out there,
So I've got a MacBook Pro with OSX 10.5.7, iTunes 8.2.1, QT 7.6.2, and Front Row 1.0 connected to my Denon AVR-3808 via the mini-Toslink and a DVI-HDMI cable. I have encoded some video files off of DVD using Handbrake utilising the AppleTV .m4v standard with dual audio tracks (1 AAC stereo mixdown, 2 AC3 Passthrough). I've then installed Perian (first 1.1.3, but now running the 1.1.4 beta) and did the whole "defaults write com.cod3r.a52codec attemptPassthrough 1" unix command to enable the passing of AC3 to the optical port after setting the digital output to 48KHz.
Now when I copy the movie into my iTunes database, when the movie is playing I can select the audio tracks menu from the playback bar and switch to the Surround track and my AVR lights up with Dolby Digital and the relevant channel lights come on screen, but when using either QT or Frontrow I'm still only getting stereo PCM sound. And it's only reading the first 2-channel track (I can tell because on one of my movies I accidentally encoded the commentary track as the stereo track which turned out to be very helpful in debugging) and not even attempting to read the secondary 5.1 track. I even installed the Sapphire Front Row Plugin to see if getting that to do the AC3 passthrough would work and no dice- the exact same result.
I'm a bit of a mac head as I sort them out for a living, but this is the first time I've tried to delve into the waters of turning a machine into a full service HTPC incorporating codecs beyond the standard quicktime set. So the question is, do any of you have this set up correctly and working that might be able to throw me a couple of pointers? Most of the info's up on the web seem to be about 6 months out of date and you get the feeling that AC3 passthrough might be generally broke in QT 7.6.x, is this the case or have some of you managed to break down the walls?
