Revo Blik RadioStation Hybrid DAB/Internet Radio
Andrew Everard
1,878
[quote user="timwileman"]crikey have i defeated the almighty forum?[/quote]
No, but it seems the mighty forum's search function has defeated you.
timwileman
296
cheers from the comments section it looks like there are better products out there, any suggestions....i would like to connect internet/dab radio to my hifi kit via the usual interconnects.....any ideas welcome
Do you need the DAB feature; are all the stations that you normally listen to also available via the internet? Do you store your music ie. computer/hdd/network link? Although the Blik had mixed reviews, the Riva Mondo would get internet radio on to your HiFi. Roberts wm201 has line out and their 202 includes DAB. Moving up there is Apple Tv and Logitech Squeezebox Duet. Also check out the WiFi forum and try googling 'reciva internet radio' for an idea of the stations available. I'm divided between the Apple and the squeezebox so it will be interesting to see where you go with this.
timwileman
296
perhaps not as all the stations are on the net, nut it would a useful backup so to speak if (and it has happened) my intertnet goes south! i dont store/use music on pc at all at the mo as my pc is a bit past it and i am loath to speand lots of money on a pc that will quickly be out of date and i will need to spend endless hours trying to figure out (luddite.....me....nooo :) the reason i want internet radio is that i like the ease of use etc of DAB but am aware that its quality is compromised wrt FM so i see internet radio as offering the best of both worlds (i hope) i will look into the models you suggested, cheersEDIT: am i right in thinking that both the squeezebox have to have you PC on all the time to work?
Yes, even with your computer off, you can still access the Squeezenetwork, and associated internet radio stations.
timwileman
296
in the end just got the DAB version of the revo blik, hooked up via rca line outs it worked staright away and picked up the stations i wanted so am happy......
