Hi . I new here! I have an old Sansui FR-D35 Turntable, is it any good? What others should I consider looking at if I change it? I think mine is direct drive, is that an advantage? (it does seem extremely quiet!)
Thanks for your advice.. I will keep using it for the moment, it does the job. The only thing is I'm not sure about replacing the stylus and how to setup the correct weight on it.
Nice setup by the way, I'm a long way behind..
My system is so different;
Denon DRA-F107DAB, Sansui Turntable, Macbook Pro 15" (2010), WD My Book Studio 2TB, Monitor Audio BX2 in Main Room
