Replacement / upgrade for arcam 7
Ianj
Hi eveyrone,
I have an arcam 7 amp that has lost a channel. I'd like to replace it whilst updgrading. I understand after reading around that a secondhand upgrade is possible. It has been recommended that i buy a Maranz pm6004 or even the Marantz PM6010 KI. I have around £150.
Can you recommend a decent secondhand amp please?
Ianj said:
Hi eveyrone,
Welcome to the madhouse.
What speakers do you run?
Presumably you mean the Alpha 7? if so I have the 7R in my loft still and it's a good budget amp. I replaced mine with Arcam A65+. The difference between the two isn't massive, but the A65 is a little more open and transparent.
Love the quirky sound of the A65+ and should be within your budget. Again, this'll come down to the speakers you have.
Hello!
I had Arcam Alpha 7R, I liked it. If you like similar sound I would recommend: Marantz PM 6004, Nad C 515BEE, 516BEE, 320BEE, 326 BEE, Onkyo A 9555, or Arcam A 65 or 75. All are very good,musical amps, with more detail than Arcam Alpha 7 has.
Thanks.
I have a pair of Mission 7331's
I suppose those amps mentioned are all upgrades as opposed to replacements?
Thanks again
Upgrade? Not realy, but many of aforementioned amps have a more detalied sound, and a more dinamic sound. The only disadvantage of Arcam Alpha 7 is that lacks some openess and it is not the most rhythmic amplifier, but highly emotional and musical. I would go for Marantz PM 60004
